Our bathroom fan broke under warranty and NuCamp sent us a replacement. They said the EZ Breeze ( I guess is what we had ) had been discontinued. Don’t have the name of the replacement just the number. Does anyone know the brand ?
@KarenELee, can you post pictures of the old EZBreeze (a square basic Dometic fan) and the new one (I am guessing a Dometic 1400 series?). I am sure people will then recognize more about this. Our 2021 TAB 400 does not have this type of bathroom fan but I have seen ones with it.
2021 T@B 400 BD T@bitha with 2016 Highlander Juliet and Andy in Massachusetts
From your picture of the broken fan - what actually broke? If the blade simple separated from the motor shaft, it should be easily re-attached as it is just a friction fit - and would be a much easier repair than replacing the entire fan. But the new fan would be an upgrade in performance...
2025 T@B 400 Boondock Black Canyon with 400Ah Battle Born and Victron Multiplus 3000 2025 Honda Ridgeline Black Edition with Redarc Trailer Brake Controller
On the old fan it started making a funny noise & the screen came off & then the blades came flying off & the motor seized up. I was in there & luckily the parts flying down on me didn’t hurt me! Not much anyway.
I followed the link you posted and i think it is that fan. Was able to get install directions , that helps . Thank you.
The fan looks to be a Dometic FanTastic Vent 3350 or similar model.
https://www.dometic.com/en-ca/outdoor/ca/products/climate/ventilation-solutions/rv-roof-vents/dometic-fantastic-vent-3350-_-21213
Or for $56 you can buy a new EZ Breeze and replace just the working guts without touching the roof seal:
https://www.amazon.com/Fantastic-Vent-800501-Breeze-Static/dp/B01G92NUSG
