Hello- Last spring, I accidentally pulled away from my campsite without unplugging 🤦🏻♀️. I had already unscrewed/almost unscrewed the ring, and must have gotten distracted. I noticed my mistake soon- the cord came unplugged immediately, but first gently pulled out the receptacle a bit. No damage to the T@B was done, and I was able to re-screw the three screws into the camper. I just returned from a two week trip and the screw holes are now too loose to stay in place anymore. I do see that the T@B shell wall is very thin with just styrofoam as the core near the inlet. Any ideas on how to re-secure? The thin foam backing that touches the T@B wall is getting pretty sad, too, but not critical. Thanks! - Sharon
2012 T@B L, 2020 Honda Passport Touring
0 ·
You should also seal around the receptacle when you re-attach it.
