rcarlson1957
Member Posts: 260
A/C Mod
Replaced the stock Danby unit with upgraded Emerson Quiet Cool unit. Has split vents, built in thermostat remote and flip down front for easy filter cleaning. Same BTUs and same dimensions. Had to drill dril in bottom like on Danby.
Lined inside and cabinet bottom with insulation, replace stock outside vent with tilting diamond plate cover. Also used layers of A/C window insulation to build out exhaust area on back of A/C to but up against the screen and help keep exhaust separate from side intakes. Used insulation to do same on outside of screen. Installed magnets on frame to attach removable vent covers to help keep exhaust and intake separate. Everything works great. 😎
I went with 1" rigid blue foam board to build an interior duct to contain and direct the hot air being pushed out the back of the a/c. The a/c pushes back against the foam and is secured in place. I plan on stacking two 3" cooling fans on the right hand side to help pull outside air into the cabinet for better circulation. I'll also add a 5" on the ceiling to help pull more air through that pitifully small roof vent.
I got to play with two of my favorite things, blue foam board and authentic silver duct tape!
I'm still fabrication the exterior pieces so I don't have a pic of that yet.
Question for you, did yours have the louvers on the outside (like you can see in the pic below)? Removing those would make the exterior design much simpler. When raised the SS lid sheds rain and when closed it prevents rain from entering when towing so the louvers aren't really needed.
"Just Enough"
I do like the door over the AC vent.
"Just Enough"
T@B 320 A/C Vent Door – TeardropShop.com
There may be other vendors. I know this one is high quality and a drop in replacement for the vent opening, albeit expensive.
2019 320 Boondock Edge - Sold Jan 2022
Trips - 48 Mileage - 63,452
