Outback S Air Conditioner
WmLock
Member Posts: 2
Hi - I'm a new owner of a 2015 S Model Outback. Does anyone know how many amps the wall mounted AC unit draws?
Thanks
Thanks
Sorry WmLock- I missed your post somehow. I don't have the spec's in front of me but I believe it was 1450 when starting and 510 after compressor has settled.
So, if I'm plugged in to my house (15 amp) I can run the AC and that's about it. Hot here in Arizona.
WmLock - where in AZ? Just wondering - I'm in Tucson. MicheleWmLock said:So, if I'm plugged in to my house (15 amp) I can run the AC and that's about it. Hot here in Arizona.
You never really travel alone. The world is full of friends waiting to get to know you! -
I don't have the A/C in our "L", but I do have a window unit of the same size and it runs in the 4-6 amp range. With yours you should lots of amperage to spare to run other things on a 15 amp circuit.The HobbiT@B, 2015-L, towed by a2014 RAM C/V
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
