Hi folks. Just doing some modification planning. Our T@B 400 won’t arrive for another 2 months.
The 12 volt charge line (1 o’clock position on the 7 pin connector) from the tow vehicle connects somewhere inside the T@B 400 and my guess is that it is either on the back of the converter or possibly right on the battery itself. Can someone tell me if they have found it, what gauge it is and exactly where it connects?
Thanks in advance.
John.
You will really have to be careful with that 350 hitch weight, and the 160 vertical rating is concerning too, not even sure why they have that along with a hitch weight rating.
From what I have read, even towing a 1000 pound small trailer with essentially no frontal area like a 400 has results in about 200 miles range. With a 400 that will surely be reduced further.
I hope it works out for you, but I think the MY is going to be stressed with the weight and the range is going to be severely limited, especially considering unless there is at least a level 2 charger at or near the CG, you will really only have 50-100 mile range one way since you need to get back home too.
