2021 T@b 320 S battery questions: I'm going from 1-12v to 2-6v AGM. What do I need?
Mlb3820
Member Posts: 3
I need a cable to connect the two 6v in series. Is 4awg correct?
Is there an in-line fuse I need to change?
Will the charging system handle the 6v AGM batteries properly?
Anything else?
Cheers,
Mark
Anything else?
Cheers,
Mark
Cheers,
Mark B
2021 T@b 320 S
Mark B
2021 T@b 320 S
4 awg is good for 60 amps conservatively so that's more than enough. I think factory wiring is smaller 6awg. You don't need to change anything else unless you plan on adding a sizable inverter (500W+) which requires larger wiring.
Thank you Grumpy_G. I'm not planning on adding an inverter at the moment. So it seems I simply need a length of the factory AWG, 6 you say? Perfect, thanks again.Cheers,
Mark B
2021 T@b 320 S -
The factory wiring to/from the battery on my 2021 320S is actually 10 AWG. I used 8 when I installed 2 6V batteries to tie the 2 batteries together to be on the safe side. 10 AWG or larger (8,6, etc) would be fine.
The load in the T@B remains the same and therefore no change of the 2 inline fuses in the wires in the tub are needed.2021 T@B 320S Boondock - 2018 Toyota 4Runner -
Oh factory is 10? I'll go with 8 as well. Much thanks.Cheers,
Mark B
2021 T@b 320 S -
Take it from them:2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4
Odessa, Fl.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
