I want to get an awning for Uteki, but I saw something about framing differences on the clamshells versus the regular T@Bs. Can anybody speak to this, or should I just contact Pahaque direct?
John & Lori in Northern VA Former owner of 2015 T@B CS Max "Uteki" aka "H@wk T@B" 2012 Toyota Tacoma Double Cab 4x4 Off-Road "Zame"
We have a 2016 Tab CS-S and are on our second side tent from Paha Que. The first one did not fit at all and after several weeks of sending photos and emails, the company said that the wrong tent had been sent (we have a clamshell and this was not made for a clamshell). Our second one just arrived. I set it up yesterday and found that it fits MUCH better. This appears to be the correct model. My only concern is that they claim:
Installs easily
using the keder (awning) rail already installed on your trailer,the T@B
Trailer Tent by PahaQue creates a completely sealed, bug-free and
waterproof environment for your gear and guests!
When in reality it does not "completely seal" and therefore is not bug-free. I haven't had it set up in rain yet so I can't comment on the waterproofing. The front fits together better than the back (clamshell end). I'm open to the possibility that this could be an "operator's error" since I haven't spent an enormous amount of time trying to figure out why there is still a large gap in the back.
Any one else have this issue?
Bren & Jenn New owners of a 2016 T@b Max CS-S towed by a 2015 Subaru Forester
Nomad, the awning fits fine on a CS, no problem there.
If you want a tent you have to get the one specifically made for the CS model. It should seal, you just have to make sure you get the correct one as the regular T@B"s and the CS T@B's have a different shape.
Regular T@B:
T@B CS:
States the T@Bpole has camped, so far Nathan & Becky... 2013 Ford F150 FX4 TAB HLR... 2012 LG T@B T@Bpole. Sterling, VA
If you would like you could use mine to test it on Uteki.
Sterling, VA
Sterling, VA
Sterling, VA
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho
Installs easily using the keder (awning) rail already installed on your trailer,the T@B Trailer Tent by PahaQue creates a completely sealed, bug-free and waterproof environment for your gear and guests!
Regular T@B:
T@B CS:
Sterling, VA
