How much does the axle move on the 2018 320s Outback/Boondock?
GeoMars
GeoMars Member Posts: 27
I want to seal the underbelly hole that the brake wire passes through to keep out rodents (https://tab-rv.vanillacommunity.com/discussion/comment/176201#Comment_176201). Does anyone know how much the axle moves (maximum movement in un-down and fore-aft directions)? I don't want to impede movement of the electrical wires that pass through the existing holes.
  • Grumpy_G
    Grumpy_G Member Posts: 766
    Not enough ..  :) Actually the answer is here https://www.dexteraxle.com/user_area/content_media/raw/2020.05_LIT-122-00.pdf page 23 and 24.
    My snarky comment is based on the fact that regardless of being standard or boondock (lite) the trailer is a bouncy castle on bad roads and backcountry dirt roads. That's my biggest gripe with the t@b design, out west a lot of campground are way off improved roads.
  • GeoMars
    Thanks, this was really helpful. And I do use it out west (mainly southern Utah) where the roads are rough.
