This is probably more a head space question sadly. Does anyone know of a manufacturer who combines a gasoline motor with a generator (or alternator) for about 20-24VDC output of maybe 500 Watts? I have no need for 120 VAC to run the trailer. I would like to as quickly as possible recharge my battery(s) in my 320 while dry camping. The bulk, noise and inefficiency of using an inverter AC source then reducing it so a charger can correctly charge the battery seems wrong. My simple system would be gas engine driving a generator/alternator and regulator to 20-24 V I would then simply connect it into my existing solar controllers already installed in the trailer. This would give me almost 25 amps into the battery. About 1 hour of running it would replace my normal 24 hour use in my 2021 if I'm too deep in the woods for solar. I might even think then about upgrading the Victrons to a higher output version. Please don't answer with the TV
I really don't want to drag around and put up with the sound of hours of conventional generator (and external charger) use. I've got some trips lined up this summer deep in the woods for a week or so and I can't count on solar.
managed by VE Smart Network
0 ·
Granted using an inverter generator to generate 120V AC just to convert back into low voltage DC is not the most efficient way of doing it but it is the most practical. There are small sub 1000W inverter generators and you could find a 24V DC power supply with enough amperage and call it a day.
The other issue is that you might be over estimating how much charge current the solar controller can deliver into the batteries and in real world conditions 25A might not be possible.
http://www.tjinguytech.com/my-projects/diy-24v-47a
https://www.progressiverc.com/collections/24-27v-supplies
