My Fall/Winter T@B projects I've completed
SLJSLJ Member Posts: 623
Here are the major ones I completed over the Fall/Winter to our 2021 320S Boondock, still a few to go.
1) Changed battery to larger AGM and moved inside (more secure and lightened the tongue).
2) Put all the parasitic draws on the battery on a switch panel (ceiling LEDs, USB ports, TV, radio, etc.) and added a Blue-Ray player and a voltmeter for the battery.
3) Changed the low fixed faucet to a higher swivel faucet.
4) Added a table bracket by the door so the table can be used as more counter space and a headboard at night.
5) Changed the outside light to red and added red LED strips with a lower switch by the door for better night vision to use when I'm using the telescope and camping at astronomy campgrounds.
6) Added a fixed telescoping omnidirectional TV antenna (no holes in the roof) so there's no set up to use the TV when in parking lots or rest areas.
7) Added a bathroom fan in the outside bathroom wall (drilling a large hole in the side of your new camper is not for the weak hearted).
8) Added a Garmin backup camera to the T@B that uses my Garmin GPS as the display.
More info on each: https://solocanoes.com/camper.htm
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
