Greetings,
'Tis the time to complete the first wheel bearing repacking on my 2021 320 Boondock. In a effort to have everything I need to complete the task, where have folks purchased the grease seals? Have seals been located at local auto parts stores? Or online? Additionally, anyone recall what size the spindle nut is? I might just go ahead and purchase a spindle nut socket for this annual undertaking. Also, did the seal come out relatively easy or is a grease seal remover necessary?
Cheers,
Ken
0 ·
The castle nut requires a 1-1/2" socket. I got my seals direct from Dexter, but I think etrailer has an alternative as well. I've heard the bearings themselves can be usually found at local stores, but I'm not sure about the seals. I used a seal puller on mine (they are cheap) but if you are careful you should be able to get the seal out with any prying implement. Either way, the seal will be trashed.
That is what Dexter designed them for. These are not 'bearing buddies' of years past, they are a well designed grease distribution system for both the inside and outside bearings.
You could do the brake service and spindle inspection and opt to repack the bearings using the Zerk/Alemite fittings after the hubs are reinstalled and the spindle nut is retorqued. You could. But, it seems like a questionable choice. Aside from possibly saving the rear seal replacement the risk of introducing dirt into the bearings should eliminate that as a consideration.
And, possibly an alternative consideration, the need to disassemble and inspect should be greater with a newer axle. The possibility of an assembly error or infant mortality due to parts or improper assembly is greater in a new unit than one that has been properly serviced. Better to catch problems before the spindles are damaged. Brakes, hubs, bearings, seals, these are all easily and affordably replaceable. Spindles are not.
Southern California
Full-timer since 2019
