Fix for A/C Blowing in Your Face in Bed (400's with big 3way fridge)
If the bed AC vent blowing in your face drives you crazy, there is a somewhat easy fix (as long as you are willing and able to cut a 4" hole in the back of your cubby.  I did this same fix on my 2019 400 and just finished it on the 2022 400.  I installed a splitter behind the drawer under the fridge and put a new outlet/vent hole inside the bottom cubby.  This works extremely well. It reduces the bed vent enough to be tolerable and also gives you additional air flow near the floor at the back of the T@b. (unless you stuff that cubby full of stuff which I don't)
Here is the link to the thread where I did it on the 2019.
https://tab-rv.vanillacommunity.com/discussion/9008/t-b-400-2019-rear-a-c-vent-blowing-directly-in-my-face-solved#latest
  • Gherzig
    Gherzig Member Posts: 99
    Smart Idea.  Did you remove the dark faceplate or has it changed from 2021 where it overlapped the edges of the cubby? See below.
    2021 T@b 400 Boondock
           Oneonta, NY
  • [Deleted User]
    [Deleted User] Posts: 831
    edited May 2022
    Its just the way I took the pic. Mine is exactly like yours.
  • P.s. your mattresses have the wrong side facing up. :)
  • bergger
    That would freeze my little dog out as the cubby is his bedroom.  Lucky for us the factory vent placement is fine for us. Nice work though!
    2021 T@b 400 BD  "Vixen Gail"
  • awh, yes that's a perfect pet cubby!
