Fan
Santo
Member Posts: 14
Our overhead fan stopped working. Any tips? Everything else is working
There should be a screw-on cap that contains a fuse right on the fan (assuming Fantastic fan). That would be a good place to start.
2022 T@B 320S Boondock
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure -
Thank you I will check
I don't see what you are talking about. There must be a fuse box somewhere I just don't know where it is. I am a newbie
I'm not familiar with this fan. You must have an older TAB model?
Have you tried a Google search with the brand and model?2022 T@B 320S Boondock
I am going to put the bed up I think the fuse box is under. But that's a good idea. The manual doesn't say anything about it. Yes I have a 2006 Dutchman tab
Yes, if the fan itself doesn't have a fuse, then the next step would be to look at your fuses in the converter in my opinion. Are all your other 12V circuits working?2022 T@B 320S Boondock
So fuse looks good. What next?
The fan noted above appears to be the Northern Breeze fan from the DM trailers. There are several threads about "replacing", but not much on repair.This group is the old Yahoo group that was ported over to the web last year. It is still an active group with plenty of info on the DM's. This is just a quick search for the fan on that site.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
