We recently took our 2021 Tab 320 CS to Zion NP then to Fishlake Utah.  Fishlake is almost 9000 feet elevation and the temps were substantially cooler (lows in the 30s) compared to the high 90s in Zion NP.  Once we arrived to Fishlake our propane stove would not work.  We were getting propane to our heater and hot water heater but no propane to our propane cooktop.  I disconnected/reconnected the hose from the propane tank a couple of times but that did not help the propane stove.  It was not a problem with the stove ignition.   The propane stove was simply not getting any propane.
Once I returned home, temps in the 70s and lower elevation I tested the propane stove and it worked fine.
Any advice is appreciated.
                0 ·
https://tab-rv.vanillacommunity.com/discussion/comment/168177#Comment_168177
It baffles me since I live at 10,200 feet and have never had any issues with propane stoves of any type up to over 12,000 feet. We regularly use our stove in out 2021 400 at over 10,000 feet and it works like a charm.
When at elevation are you actually getting propane coming out of the stove and it just won't lite or are you not getting any propane to the stove at all?
Wish we knew what the actual root cause was.
Thanks
