Access to Jensen Media Cube
DMattern
Member Posts: 24
I'm considering installing a subwoofer to add some depth to the audio, and the Jensen Media Cube has a subwoofer output, but getting to the back of it isn't obvious to me. How can I access the back of the Jensen in a current model (21-22) Boondock 400?
Bubbles - 2022 T@B 400 Boondock
Tug - 2021 F-150 4x4 Hybrid
I may be wrong but I think you can work it out of the hole from the front. I haven't tried to do it though.0
I added a BOZE sound bar below the tv and that thing is awesome!! It was a bit tricky to figure out which optical wire was needed to fit back of tv but once I got the right one my sound is excellent. I don't even use the cube at all for anything.0
Easy peasy. Take a small flat screwdriver and slide it under bezel, it doesn't take much to remove it. Then 4 screws hold in the cube and slide it forward. There is slack to access the rear wiring. The wiring is labeled.2022 T@B 400 Boondock
South Jersey2
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
