My SeeLevel II Tank Monitor seemed to be functioning ok until yesterday when I was de-winterizing my 2018 T@b 320S. The battery level had been consistently reading 12.3 volts prior to yesterday and the various tank level readings seemed to be fairly close to what they should have been. Yesterday, battery voltage started reading 9.3 every time I checked it and the tank readings were erratic and not reasonably consistent with what they should have been. At one point, each tank reading was 13% - when I knew black was empty and gray and fresh had water in them - but shouldn't have been reading 13. Today I drained the gray and fresh and all three tanks did read 0 and battery was still 9.3. None of the error codes described in the manual have appeared. On front cover of manual, signal levels written in are black, 86; gray, 49, and: fresh, 37. Sender heights written in were 5,4 and 4, respectively. Trailer is connected to shore power.
2018 T@B 320S. Tow vehicle: 2020 Toyota Hylander Hybrid
0 ·
Assuming the 'battery' voltage reading is correct . . . weird tank reading would
not be a surprise.
2] Assuming 9.3 Volts readings is correct - - -
a) Your Convertor is not 'on' or is no longer outputting correctly
b) SeeLevel maybe reading your trailer Battery . . . which has been drained very low
due to the possible Convertor failure.
Try these things:
A] Switch circuit breaker #1 off and on. (the one next to the Main 30A)
Circuit Breaker might have tripped - - - - is SeeLevel voltage above 12V now?
B] Switch the battery Cut-off Switch to Off - - - what does SeeLevel read now?
If Convertor is not outputting voltage, SeeLevel will now read Zero.
@jalars8 when was the last time you saw 12.3v on the SeeLevel?
In between that time and now, was the battery switch left on?
Were you plugged in or only using the battery?
Can you use a multi-meter directly on the battery to measure the voltage?
Sold 2023 Tab 400
Sold 2018 T@B 320S
Yes, you are correct . . . for that mini-test-data-point . . .
If trailer is connected to Shore Power and SeeLevel reads zero volts,
then the Convertor is most likely not working.
However, if the SeeLevel continues to read 9.3V then we have more questions as:
- = - The convertor could be outputting 9.3V (a really weird failure mode)
- = - The SeeLevel itself has failed. (I've no memory of the SeeLevel Panel being reported as BAD
while several posts/threads discuss the Seelevel Sender unit[s] failing).
Sold 2023 Tab 400
Sold 2018 T@B 320S
