Isn't this producing 24v?
slick2699
Member Posts: 3
Hello! Recently bought a 2022 320 boondock which to my surprise had 2 LifePo4 100ah batteries installed. Everything runs as it should but after taking a closer look it appears they are wired in a series, which as I understand should be producing 24v? I'm a newbie so I assume it's fine, but what am I missing? Thanks!
Your photo shows batteries connected in parallel - positive to positive and negative to negative. As it should be. Series connection would involve a positive to negative connection between the batteries.
Roger and Sue Hill | 2020 T@B400 Boondock (Cryst@bel) | 2022 Land Rover Defender 110 - P400 | San Juan Island, WA3 -
@slick2699 ; Your Batteries are correctly connected in Parallel.
In fact the Go Power literature states they can not be connected in series. (perhaps because that will confuse the built-in BMS {battery management system})
You can tell the batteries are in Parallel because the Positive Terminals are connected (shorted) together.
The figure below is from the Go Power 'Quick Start' flyer.
Adventures: 50 Nights: 415 Towing Miles 50,6502 -
Thanks guys, i see now. I think the flipped 2nd battery was messing with my head.2
yes, that is odd. I would flip the one battery back the other way round (as shown above in the illustration) and use shorter AWS no 6 battery cables to reconnect them back in parallel.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.1
- 31 "FOR SALE" - New/Used Trailers
