Solar help needed
Sharon_is_SAM
Member Posts: 10,061
Well, here we are down to 80% SOC on the Victron BMV and the wattage remains at “0”. Yes, we are in an area with limited sun and passing clouds, but we should still see something! Yesterday we arrived to our campsite and we saw no wattage as well. Here are some current screenshots. We have disconnected and reconnected and removed the fuse and replaced. We have disabled charging and reenabled charging. The BMV voltage is only about 12.4 and the Victron MPPT battery voltage is reading 13.3 and Float. Can’t figure this out.
Found the culprit. The 30 A fuse on the charge controller battery pigtail was not operational. Removed and now we are charging.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 916 Introductions
- 72 Teardrop Groups & Links
