homemade awning is our favorite awning
I made my own awning for our T@B 400 because the two different ones I bought from All Pro Adventures were impossible for me to slide in to the aluminum awning rails, so I had to return both of them minus a restocking fee and shipping.
So I bought a heavy duty 6' x 8' tarp with grommet holes along all the sides. It was $20 from MyTarp.com  I also bought some "Quicklinks" and some key rings that added up to another $20. also bought some SaphiRose Adjustable Tarp Poles on Amazon for $40, but you don't have to spend that much.
Put the Quicklinks and the key rings into the grommets of the tarp, along the 6' side and the 8' side so you can choose which side to use when you go camping. I would also glue the Quicklinks closed because they will eventually vibrate loose.
Bottom line: It slides in MUCH MUCH easier than either of the awnings we bought from All Pro Adventures. And it really doesn't look bad. We ordered silver on one side and  black on the other, and we are very happy with it. It doesn't hurt that it only costs $80!  Oh, and you can put the poles in the last grommet
for maximum length, or into the the next to the last one to make it shorter and have a little sunshade flap... so it is very adjustable.
Karen and Chris
2021 T@B 400, 2018 Land Cruiser
Dallas, Texas
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view.” Edward Abbey
  • Babs
    Babs Member Posts: 28
    Good job!
  • Mags80
    Mags80 Member Posts: 15
    Love your inexpensive solution. I added keder rail insert to a King Camp canopy and slide it where needed as the sun moves. When you’re on a journey, I see you can probably do the same with the adjustable poles.
  • georgianwinds
    georgianwinds Member Posts: 41
    Nicely done. Quite simple and does the job just fine. And for a whole lot less than most of the commercial alternatives. Congrats.
    I have acquired a Rhino-rack awning (for free) and would love to figure out a simple way to attach and deploy it.  So, a bag awning attached to my @T@B 320. Your clips may have given me an idea for attaching at the campsite (??) but I was looking for a more permanent attachment solution with the awning remaining in place on the side of the camper while travelling. Any ideas? Let me know. Much appreciated and happy camping.
    Camper - 2019 T@B 320 CS, TV - 2021 GMC Canyon Diesel
    Scott & the S.S. PorT@Bella
    My Teardrop Mods  https://georgianwinds.wixsite.com/teardropmods
  • Marceline
    Marceline Member Posts: 1,779
    edited August 2022
    Sort of similar, but after trying the Pahaque awning and visor, I'm really happy with the old-fashioned awning from Marti's Awnings.
  • Pintoplumber
    Pintoplumber Member Posts: 182
    @Marceline, I showed this picture to my wife, and she really liked it. What size is yours? I believe we’ll have to get one.
    2016 320 CS-S  1954 Ford F100  2017 Chevy suburban  2023 Chevy Silverado 1500
  • CruiserCamperChris
    CruiserCamperChris Member Posts: 93
    pintoplumber you need to read my write up. You will see that you can not "get one". You have to buy the supplies and put it together yourself. There is nothing to it. If you can put keys on a keyring, you can put this together yourself. When you read what I wrote, you will see what size I opted for. You can get smaller or larger, but I think my size is just right.
    Karen and Chris
    Dallas, Texas
    Marceline, do you have a photo as to how your pretty awning is anchored to the roof of your T@B?
    Karen and Chris
    Dallas, Texas
  • Marceline
    I’m sorry, I’m not sure (I bought it used) and I don’t have easy access to check for you. I would take a look at the sizes on her website and then use a tape measure against your trailer to figure it out. Maybe something like 6x6?
    You could also call Marti and ask her if she remembers making one for a T@B.
  • Marceline
    It has a bolt rope that slides into the keder rail. Because it’s narrower than the awning or visor it’s easier to feed it into the rail.
    pthomas745 I have bought and tried those Awning Hangars and they work on the narrow slits in awning housings but they are too small for Keider rails and just fall out.
    Karen and Chris
    Dallas, Texas
    They do have to be the right size.  Plenty of them do fit.  You can even make your own.
    edited August 2022
    @pthomad745 I did make my own. They work. But thank you. I’ll take a look and maybe try them out. I bought several awning hangars and they were all to small. I still haven’t seen any awning hangars large enough to attach to our keider rails. Can post up a link? Do you see a problem with mine. the DIYs you reference do look to be smoother.
    Karen and Chris
    Dallas, Texas
  • Pintoplumber
    @CruiserCamperChris : when you use the @sign and the name, that gives the person you’re talking to a notification that you are talking to them. I was talking to Marceline. Being a guy, I could go for the Harbor Freight look, but my wife wouldn’t let me put it up.
    @Pintoplumber thank you! I hadn’t posted in here in awhile, and forgot all about that.
    Karen and Chris
    Dallas, Texas
    @CruiserCamperChris I only added the links and stuff to the awning hangers just for general ideas.  Your solution is perfectly fine, and has added to the overall state of the art!
  • JohninMissouri
    JohninMissouri Member Posts: 28
     CruiserCamperChris;    Excellent work!  Photos are especially helpful to help understand the details, and enjoyable to view too.  I copied your work.   Will try it out this week while camping!
  • Jeffma
    Jeffma Member Posts: 3
    I made a couple of these just to have a few extra hangers and attachment points. However instead of gluing the quicklink threads, I slid a length of shrink tubing over the quicklink nut and shrunk it down. Should keep the quicklink from unscrewing as well as provide a bit more girth to the link when slid into the keder rail.
    2022 Tab 320 S Boondock
  • SLJ
    SLJ Member Posts: 666
    The Quick Links is a great idea for attaching things to the rail. I prefer an SUV awning over the top though so I don't get any rain between the side and awning and the door can stay open.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • Jeansor
    Jeansor Member Posts: 28
    You could also sew keder rope onto one side of the tarp, that way when it rains there's no rain coming in between the tarp and the trailer. I used keder rope on an suv awning and it works great.
    2013 Nissan Frontier
    2020 T@B 320 S Boondock Edge: Sm@lls
