What to do with used AGM 200aH battery?
Aubrey
Member Posts: 160
My discovery battery started getting too tired too fast so we got a Renogy 200aH AGM. The old one is not toasted, just old (looks like it came from Nucamp with the 2018 T@B 400)... I hate to send it for scrap if it has some life left in it, but obviously we committed to a fresh battery and wouldn't want to combine the 2... definitely don't want to transport it either..
maybe a 12V fridge for my garage and utilize the solar panels when not camping, cost free refrigeration for shop beers?
Build a powerbank of outlets for solar charging of devices during power outage? Hmmm...
I've kept my original battery in the garage. I have a couple of inverters that I can attach to it and run things with it. If you know how much power your little mini fridge uses, it would work well attached to a solar panel and an appropriately sized inverter. Here is the basic idea (with a different battery). A 12V adapter attached to the battery, and the inverter plugged into the adapter.
Towed by 2014 Touareg TDi -
Granted not everybody has a gate opener but that's where I put old deep cycle batteries to use. Even at a third of the original capacity they still work for another year or two.
An automatic gate would be classy, and delay the reassessment of our property after adding a second story!!
I will look into the inverter, is that one like the one we sometimes use in the car through the 12V "lighter" style plug? If so I will find an adapter and experiment some. -
Take it to a place that sells batteries, or a recycle center, and they'll recycle it.Rich2019 T@b 400
The inverter is the same type you used in your vehicle, yes. That one is a 300 watt inverter. If you want to use bigger devices, the little "plug" adapter will not work. The 15 amp fuse in that cable will blow on a 180 watt device. You would need to use an inverter that attaches directly to the battery, with a larger wattage capacity, to use larger devices. And, a multimeter to keep up with the state of charge of the battery.Tons of inverters like this: https://www.amazon.com/BESTEK-300W-Power-Inverter-Adapter/dp/B004MDXS0UThis is the 12V adapter. Well made cable. Lots of these sorts of things. Check to see what type of battery posts you have to make sure it will attach.
I sold my old 200 AGM for a few bucks. A young couple doing “van life” were very excited to have it. Since they were only powering a few lights and a water pump it still had more than enough life for them.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
