Need help - Which part of the cabinet is the chicken and which is the egg ?
Dame_plume
Member Posts: 75
My speaker passenger side had stopped working after my dealer installed my Furrion camera. I let it go for a long time because I thought that I was the one doing something wrong because I was new to the T@b. Today, I unscrewed and checked both speakers and the wiring on them looks fine. So, my husband and I put a little plumber camera under the "night stand cabinet" and we saw that the installer had accidentally moved the speaker wire and it is sitting (and melting) right against the Alde "heating blades". We want to remove that bottom cabinet and see what else might be wrong there as well as replace and secure the speaker wire.
I unscrewed the couch and slide it forward, so I have a comfortable working area. Now I need to know what, and in what order I should unscrew things in order to get to those wires without messing up.
We want to do it ourselves because there are NO knowledgeable dealer around here. The closest is a 4 hour drive and he is the one who installed the camera.
Sylvie and Mike, Ontario, Canada / 2020 Tab 320S (Charlie) / 2021 Chevrolet Colorado LT (V6) Enhanced Towing Package
"The only place where you start at the top is when you dig a hole"
See how I removed it here on our 2017 320S.. (did not remove any seat)
https://tab-rv.vanillacommunity.com/discussion/comment/167199/#Comment_167199
@BrianZ Thank you ! This is exactly what I needed. I did try to remove it exactly the way you say but could not get is out. I will try again.Sylvie and Mike, Ontario, Canada / 2020 Tab 320S (Charlie) / 2021 Chevrolet Colorado LT (V6) Enhanced Towing Package
"The only place where you start at the top is when you dig a hole" -
nüCamp Support web-site comments on removing 320S rear lower cabinet:Several folks have reports removing/reinstalling the cabinet with zero issues.'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180 -
The issue I had after removing the screws was trying to lift the cabinet out while on my knees with no leverage leaning forward. By laying on my back, my whole body acted as a counter weight to get the leverage to lift it out above my head.-Brian in Chester, Virginia
Thank you guys! What a wonderful community to be part of!
It is done and both speakers are now working. Looks like nothing happened.
- 919 Introductions
- 74 Teardrop Groups & Links
