Does anti-freeze brand matter?
The time has come to winterize the plumbing again. On the assumption that propylene glycol is the way to go (vs ethanol or blowing out), does brand matter? What does nüCamp recommend?
2020 Toyota Highlander + 2021 T@B 400 BD
Truckee, CA, expat, now driving out of Reno
Yes. See attached thread.
https://tab-rv.vanillacommunity.com/discussion/16197/antifreeze-for-plumbing-winterization
--Marlee
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota0 -
I saw three brands (Walmart, Camco, HomeDepot) mentioned with no preferences. My take on the question is, then, brand doesn't matter but the contents do. As long as it's propylene glycol you're covered. Vodka, while potable, lacks temperature range.
Truckee, CA, expat, now driving out of Reno0 -
I'll also include that it you live in a normal winter climate or warmer winter climate the standard -50 antifreeze is fine. If you live in an very cold climate like I do then I'd use -100. I use the Prestone -100.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado0 -
Point taken. Even 30 years in the Sierra Nevada we never needed Prestone's -100. Stay warm.
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
