Lost 3-way Norcold fridge fan that cools the exterior fins
Mags80
Member Posts: 15
2018 t@b 320s…I forgot to check upper exterior vent cover and it blew off, taking the fan with it. Can’t use my fridge until fan is replaced. There are a couple loose wires but the thermocouple is still attached. The fan was factory installed and attached to the vent cover. Suggestions for efficient, quiet fan welcome. Simple to install would be great too.
Thanks for input, tips. links. This will be an expensive ‘oops’.
No sure this discussion applies to the 2018 model, but here it is:
https://tab-rv.vanillacommunity.com/discussion/2635/noisy-norcold/p1
Given the cooler temps in the fall the fridge should still work fine. AFAIK the fan is a Nucamp addition and not part of the fridge itself.
Pretty much any 12V fan typically used for PCs will be fine. Just make sure it's the right size and a 2 wire 12V DC fan. -
Ditto Grumpy’s comment.‘18 Tab 320S- mfg’d 4/17, acquired 9/17
Huntington LI -
Thank you rcuomo, Grumpy_G, Tabaz for your comments.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
