My Interstate wet cell battery needed replacement, so I bit the bullet and moved the battery location under the drivers side compartment housing the electrical WFCO and installed an older 50 aH Optima battery I already had along with a new Victron BMV-712. Now everything is working I need to get a new larger AGM battery. I can only fit one Group 31 size battery so looking to get highest amp hour rating that I can fit which appears to be from 100 to 135 amp hours.
Here are two of the Group 31 batteries I am considering:
| Mfg |
Model |
20 hr amp-hrs |
Weight |
ah/lb |
$/ah |
| NPP |
NP12-100Ah |
100 |
67 |
1.49 |
1.9 |
| VMAX |
XTR31-135 |
135 |
74.8 |
1.80 |
2.4 |
I would like to get the 135 amp-hr one but can a battery with only 12% more weight really provide 35% more capacity or is this just marketing hype? I assume in reality battery capacity must be related to the amount of lead used hence battery weight.
https://www.trojanbattery.com/motive-agm/
I have never felt very confident in the WFCO charger since I can never tell if it actually performs a charge above about 13.6 volts. I saw where you can replace the charger section of the WFCO with another battery charger, but I don't think that option covered Lithium battery charging. Not sure how to keep the WFCO for house 12 volt power supply and use a separate dedicated charger for either new AGM or Lithium battery.
I was thinking of making a change from using the WFCO charger anyway. If and when I do, I will make sure I get a charger that can handle any type of battery. If I use an AGM battery now, I can live with the WFCO and supplement it with my Optima battery charger like you do with your Victron charger and don't have to change out my solar panel controller.
