Look What I Found
I’ve been trying to do some parasitic battery drain testing, and look what I found. Apparently when my solar panel installer reused the existing holes for the solar cables, they created a situation where this delicate thermostat cable was damaged where it was running to the Alde system.
It is amazing that I noticed.This eventually would have caused a catastrophic failure. In general, the wiring is very tightly strapped in with cable ties. This can be a double-edged sword because if it does start to move a tiny bit, it can cause abrasions on the wiring.
My fix isn’t elegant, but I think it’s fairly robust. After repairing the two damaged wires with crimped butt connectors, I wrapped it in electrical tape to keep it from snagging.
(previous 2018 T@B 320 Outback, 2021 Jeep Grand Cherokee V6)
Maryland
  • RobynE
    RobynE Member Posts: 31
    Wow, pro fix on that!
  • Slackers
    Slackers Member Posts: 490
    Catch of the Day!
  • Tabaz
    Tabaz Member Posts: 2,420
    The first photo doesn't show where that cable was rubbing against something.  Do you have a photo of the location of the actual rubbing point?
  • Trailpixie
    Trailpixie Member Posts: 205
    (I realized that the first pic in the group above was probably impossible to figure out because it was sideways. )
    In the picture below, I have marked two thick black solar cables with red. Then I put a purple circle around the spot with arrows pointing to the spot where the thermostat cable was pinched and chafing. It really wasn’t that badly pinched.
    Maryland
