Low point drain has broken attachments to bar
At the point where the low point drain is attached by screws to the frame of the Tab 400, screws snapped. Unable to reconnect to replace. Has anyone experienced this problem? How did you resolve?
  • MuttonChopsMuttonChops Member Posts: 1,909
    my 320S fresh water tank drain 'frame clip/bracket' has broken.  The plastic part not the screws.  However, I've not fixed it yet as one screw is super rusted in-place and it will take more effort to remove than I'm interested in investing while it is 20F outside ;)
    Do you have a picture of how your drain brackets are broken . . . might help others to provide suggestion.
