Dicor lap sealant
Jetman
Member Posts: 45
can you use Dicor lap sealant to seal around edges of fantastic fan, old sealant is starting to crumble, no leaks as of yet.
I replaced my bath fan and used Dicor lap sealant that around the new install with no problems. I think you might scrape away the loose bits and clean with alcohol to get it to adhere well2019 T@B400 Boondock Lite "Todd"2016 Toyota Tundra 5.7 Crew Cab
Yes you can use that. Or you can put some eternabond tape around it for a quick easy fix. I did that on a fan on my old trailer that was actually leaking. I sold the trailer 4 years after that repair and it still did not leak. I honestly do not know what is a better solution. Dicor certainly works very well but it does need to be replaced from time to time. I'm sure eternabond does as well but it certainly is easy to apply. I always keep a roll in my trailer tool bag in case I need to make an emergency repair while out traveling.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado -
Bergger
Thanks, for this I did order some of the tape sometime back for something, I thing was suggested for elbo at potty, which as leaking and I found a better fix.Do you need a hard roller to affix the tape to the ridge of the fan housing and how do you overlap it and assure that it seals with no leaks.
anyone with a video of the application?
Thanks
jetman -
Here's a counter-argument against eternabond: https://www.rvtravel.com/group-shouldnt-eternabond-tape-rv-roof-1082/2019 Tab 320 CSS, 2019 Ranger TV, OH
On roof fans, vents, skylights, and other flat horizontal surfaces use Dicor "Self-leveling" lap sealant. For side windows, compartments, and fittings on the sides and vertical surfaces use Dicor "Non-leveling".2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York -
The dicor on my old trailer was very thin and I actually just used eternabond over it. Like I said it was still completely sealed after 4 years. I would not hesitate to use it again. If I ever have to use it again I would remove the old Dicor but heating it up with a heat gun or hair dryer and use a putty knife to remove it. I think both dicor and eternabond are good products but I believe eternabond will last longer and in my experience is less likely to crack and dry up over time. Dicor is very good but seems to require more frequent maintenance. I think eternabond works very well on fiberglass and aluminum roofs. The arguement above is for membrane roofs which I'm sure would be much harder to remove eternabond from if needed. Everybody has an opinion on what works best. I've never replaced dicor with more dicor so I can only comment on my good experience with eternabond.2021 T@b 400 BD "Vixen Gail"
Thanks for your advice
One bit of advice on using lap sealant. Use it generously. I know it’ll look like a mess but go thick and heavy with it. It’s good stuff.2021 400 BD
2020 Tacoma TRD Off-Road
- 917 Introductions
- 73 Teardrop Groups & Links
