Anyone who owns a 400? Several questions, I have just purchased a 2018 400, low time utilization and in very good condition. I tried to take down several panels up front around the divan to see if there were any Alde /lace hoses with major bulging. Seller did not lik3 the fact about disassembling his camper and he has used the Alde for heat these 4 years off and own.
got tr@iler home and I took apart the couch area and there are several places in this front area that have the beginnings of “the bulge”, not bad but are there.
my questions is how does one get the Alde fluid completely out of the loop so that I can start to open up the hoses and to inspect the proposed corrosion on the aluminum posts on the convectors and specific to the 400 in this area, the connection joints that have been plugged together with the aluminum connectors, and the CRAP squeeze plugs that NuCamp used since new.
cutting the tubes may release lots of fluid, and what can I use to replace the aluminum connectors in this space that is numerous.?
i have heard that 3/4” brass pipe will work, as it is non corrosive to the base fluid, from a video by Mark someone who has done a complete analysis of this fiasco.
The remediation video is very interesting and very informative; however it is related to a 320, not a 400.
Thanks and Help,
jetmandabbs
0 ·
managed by VE Smart Network
Just an observation in my 2021 320 since there's been discussion about double clamping, some hardpipe to rubber connections do have two clamps (contant pressure type) while some have just a single clamp. I observe this at the convector connections, elbows and and straight coupler connections. There doesn't seem to be a consistant clamp method (single or double) at any point of connection. The only thing that is consistant is the placement of the clamp on the rubber at the hardpipe interface, which always is at the end of the rubber piece. This would maximize the "stagant glycol" in regards to the theory as a contributing root cause to the corrosion issue.
Southern Maryland
An alternative, and I think simpler, method to drain the older 400s is to:
- Open the drain below the trailer/Alde with the red cap to get a gallon out.
- Expose the reservoir in the closet and you'll see a bit of fluid remaining going to one of the two hoses. There is a check valve preventing that portion from draining. Disconnect that hose, drain it in a bucket, then tape it to a shop vac hose and pull the remaining three gallons out with the shop vac. Have a towel in the closet it area to catch any minor spillage while working with the disconnected hose.
what I would like to do is to clear out all of the century glycol that is in my 2018 400 so I can address to issue of the small bulge's in several of my pipes and either scotch brite the aluminum to rid the corrosion or either change the tubing to copper with new clips along the bends and joints. The buldges that are on the convectors are very small and should be able to be cleaned, I hope? After I check all fittings I and going back with the century as I have heard that the Romar fluid does not work with older that 2023 models, again ?
thanks for and and all replies
jetman
I agree totally with your situation summary above.
(Well, except I'll be using my previously documented 3-way valve.)
