Have a 2018 400, I just bought and I think the two 6 volt AGM batteries are original. They on shore power show 4 dots on the control panel inside. When remove shore power within three days lights on panel will go to two, nothing on in camper. If cut disconnect switch off very little change.
i have not removed the cover over the batteries to see what amperage/ brand they are. Question is once remove cover how do I check voltage to see if good or bad? If need to replace, what type of AGM Is preferred brand, how to make sure installed properly, and can I use a trickle charger on these types of batteries as I did with 2015 320S with wet battery. Not much room where they are under the bed and with the battery disconnect switch.
Thanks for any help rendered
jetman
0 ·
There is a small junction box next to the battery under the bed that is connected directly to the battery. You can use this to measure the battery without taking the battery cover off. Take the junction box cover off and you'll see both battery wires coming to terminals on each side. Be very careful not connect/touch both terminals together as they are very close to each other.
To check your battery health, I would charge the battery fully, then turn off the battery switch. After letting the battery voltage settle for at least an hour, check the voltage with a multi-meter at the junction box. Then check the voltage again a day or two later. Good AGM batteries have very low self-discharge, compared to lead-acid batteries, so you should not see any significant voltage drop over the course of a few days with the battery switch off. If you see a voltage drop, you're battery(ies) needs to be replaced. Given their age and the readings you're seeing on the trailer monitor, they are likely toast.
The battery capacity for the dual 6V configuration is 224Ah (amp-hours), so useable amp-hours is half that, as noted above.
This comment/response is just to provide some additional visual / diagram reference points for you.
Typical DC Distribution Block Horigan referenced:
Note when you measure the Battery Off Voltage any solar panels (if installed) must also be Off
which may require your pulling the solar panel in-line fuse(s).
if do need batteries any suggestions as to brand and where to purchase ?
Here are the specs on the battery NuCamp used for a while. A single lithium is now the standard.
Edit: I corrected my terms above and measured my trailer. The ratio is 1:7 for the 2018/2019 400s, so the 70 lb weight reduction of the battery will result in a 10 lb increase in tongue weight.
