Alde bypass mode
On the nautilus system is winterize mode the same as Alde bypass mode?
  • Binghi
    Binghi Member Posts: 415
    Yes, when you are in Winterize mode you bypass the Alde water heater tank.
    pthomas745 Administrator, Moderator Posts: 4,656
    Depending on the year of the trailer, etc. Nautilus: in the P3 manual, the "Red Handle" serves as the "bypass".
    In the Nautilus 2.5, there are only a green and blue pair of "handles".  The Alde bypass is a "big" red handle inside the Nautilus compartment marked "Normal and Bypass".
