Our first real mod to our 2023 T@B 400 will be adding a Progressive Industries EMS LCHW30 hardwired surge and electrical protector. We decided to install it in the compartment accessible by the hatch on the passenger side.
We spent some time this morning removing wood panels, drawers, etc. to get a good look at the routing of wires. It appears the easiest method will be to disconnect the 10GA (orange) main cable at the distribution panel. We'll then reroute it to the EMS and run a new line to the panel. Thoughts?
BTW, with everything exposed it is easy for us to take pics of anything you may want to see...
2023 TAB 400
Virginia Beach, VA
1 ·
I pulled the bed panels and after fixing a loose inverter and battery which had bounced up and over the tab meant to hold it in place moved over to the drawer between the sink and stove...just like you. I have not yet opened the panel below the drawer since I had to come inside and do my day job for an hour or two (on a Zoom meeting right now
It makes perfect sense to install at the breaker panel. I had no idea there would be room. I will soon find out. It will make a very clean install to move the romex from the main breaker to the EMS and run a new wire to the main breaker. Super clean...no need to cut...no need to try and find slack. I am going to see if I can find a good way to mount the remote monitor near the rest of the control stuff by the entrance door to the camper.
So, yeah, sounds good to me! Posting pics would be great...saves me the trouble
Jericho, VT
That way we can see any error code looking through the outside hatch when we first hook up to power. Don't think there is room back in the cabinet with the WFCO (or at least I wouldn't want to pull out the WFCO to get to any vacant space). Once unhooked from the distribution panel (WFCO), the supply cable is loose and will be relatively easy to pull back to our intended location. Then we'll just add more cable to complete the circuit. It looks like 6FT will be more than enough.
Let us know how your install progresses. And thanks for the input!
Virginia Beach, VA
T/V Ford Ranger 2023 4x4
Virginia Beach, VA
Is this true? If so, should an easy bypass be installed in case it fails?
Minnesota and Arizona
The only caveat we found to using the hardwired EMS is that it doesn't like when you hook up to some generators. It reads as a ground fault error and will not allow electricity to flow (as I understand it, this issue can be overcome with a neutral bonding plug on the generator).
Virginia Beach, VA
Jericho, VT
Edit to add: Looking at mine, the neutral bus bar is further back, right where your EMS seems to be mounted. Que Sera Sera...
Virginia Beach, VA
I did not have to move mine. I would have thought about moving it to the forward side of the space. Either works...or of course where you were planning is a fine place if you don't have the remote head. You can see the gray/silver "telephone" cord in the shot. I pulled it through to under the sink and might ultimately mount it with the other control stuff by the door.
Jericho, VT
South Jersey
South Jersey
Jericho, VT
Below you can see the (orange) Romex in the chase right after we ran it all.
Virginia Beach, VA
Jericho, VT
I removed the cable clamp that held some bundled wires to that wall and it only used a 1/2" screw since the wall between that area and the storage under the sink is only 1/2" thick. I used 1/2" screws (x4) to mount the EMS.
I routed the the remote display cable into the nautilus compartment and installed just above the compartment's light. I'll laminate the error code and mount it to the nautilus access door when I get a chance.
South Jersey
Jericho, VT
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
Virginia Beach, VA
South Jersey
I want a hardwired EMS in order to get a more accurate voltage measurement (in the TAB versus at the electric pedestal), but in other threads and in Amazon Reviews, I'm seeing many complaints about the 60Hz buzz from the unit. What are your experiences with the noise of the unit when mounted in your chosen locations?
Madison, WI
Virginia Beach, VA
https://revkit.com/donmontalvo/ | https://donmontalvo.com
To answer your question about hum/buzz...
When I first installed it I did not notice any noise. That being said, after a few trips out & back a noise started up, it was rather loud. I contacted Progressive and submitted a warranty claim, provided them details (like voltage in, frequency, etc.) and they quickly sent out another unit. I was going to (and eventually did) change the original noisy to "...render the device inoperable...) per their instructions but experimented a bit on the noisy one
Night and day difference, went from being very load to can't hear it at all. I was going to go back to Progressive with this info (never did) and recommend they change the contactor mounting so that it essentially "floats" rather than being hard mounted.
South Jersey
Madison, WI
I installed on the left hand side wall, behind the breaker box. The number 10 wire makes this install a pain.
Considering the BUZZ problem that many people seem to have with these EMS devices (both Progressive and Hughs), I regret not replicating RTWCTS and installing in the passenger side well. It's an easier location to access if you need to replace or fix a buzzing unit. Thanks to all who posted their installs and gave me advice.
Madison, WI
Winner, winner chicken dinner. Retired (as of Jan '25) EE.
South Jersey
Virginia Beach, VA
