Resetting Alde after Glycol exchange
madtrout
Member Posts: 63
Just fired up the Alde after having the glycol changed to the new spec, and while the heat worked, the hot water was only heating up to 104 degrees as shown in the service section of the menu. I reset the system and now the water is back up to 143 degrees. Just aheads up if anyone else is having the same problem. Happy Camping, Mark
2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland
2008 Toyota Tacoma
2
@madtrout - how did you “reset” the system?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
In the settings menu is a system reset button2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland0 -
I believe it was part of the service sub menu. I’ll check tomorrow when I’m back in the TAB2021 T@B400 Boondock
2008 Toyota Tacoma
Just checked in the TAB and if you scroll to the fourth settings menu, of the Alde control there is a reset button. Its in the the same menu panel that has the service button. Hope this clarifies. All the best, Mark2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland2
