What is the voltage on your battery? The fridge requires 10.9V and will shutdown below 9.6V I'm not sure if the shutdown includes the light. But something to check?
2025 360 CS (awaiting delivery) 2021 TAB 320 BD (w/new owner having fun) 2021 Jeep Grand Cherokee Southern Maryland
Hi, Another thing I may check is to confirm you have both 12V power coming into the WFCO (at the fuse) and the output side on the fuse. That will tell you which side of the circuit the issue is.
@Yoshi_TAB and @pthomas745. I found the problem. The breaker was tripped and I didn’t think to check it. Yours comments guided me there. Thanks and my trip from Myrtle Beach to Ohio will be more fun.
Southern Maryland
Southern Maryland
Southern Maryland
