T@da not getting power from the battery.
Carolyn
Member Posts: 129
The interior lights work on shore power but not on battery. The battery has been tested and is in very good shape. All fuses in the power center have been checked and are okay. I have been told that there is a fuse or circuit breaker between the battery and thd power center but cannot locate it. Does anyone have any ideas?
2014 CS, tie-dyed exterior, "Tabula Rasa" and 2009 T@da also tie-dyed, “Grateful”
Look around the battery ( in tub base and/or frame ) for something like this:
Once located you can test, if bad then you can decide on searching for a direct replacement or wiring in the newer 'automotive blade' fuse holders.
This thread has some discussion - - - T@da in-line battery fuse
Shortstop fuses are still widely available. You will need a 30 amp type if you find this is the issue.
Towed by 2014 Touareg TDi0
