Anyone have experience with this? Not much found on the search. Noticed water dripping from the plastic undercover at the edge on driver-side wheel while repacking bearings. Removed fasteners and plates from the driver-side edge of the cover and a pint or so of fresh water poured out. 2 weeks ago dewinterized AF from water lines and sanitized the lines. Did not notice any water under TAB at that time. No pink discoloration, chlorine smell or old stale water smell in this mostly clear collected water. I'm guessing there is a fresh water system leak somewhere under there so need to inspect. Tips for removing the bottom cover?
2021 320S BD
2020 V6 Chevy Colorado
1 ·
As for tips on removing the Air Shield . . . none, just know that removing all the screws is easy . . . while getting them back into the same frame holes is a real pain. If you don't have a project reason to drop the Air Shield - - - save yourself and your back some pain and leave it be - - -
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
Removing and re-installing the over was fairly easy. I used a drill/driver with a 5/16" nut driver. Just be sure to line up each screw with its hole when putting them back in.
TV is 2007 Kia Sorento EX with 3.8L engine
Interesting snake stories but cannot figure out how a snake got under there let alone leaves or water.
2018 Toyota Highlander, XLE
Wisconsin
