leak at quick connector
jalars8
Member Posts: 52
Any suggestions on fixing a leak at a quick connector? Attached photos show the connector up close and the bigger picture. The up close shows the connector and another fitting on the right. I am not sure what the purpose of the smaller fitting on the right is - seems like the tubing coming in from the right should just go directly into the quick connector - something I am not understanding. I think the leak is at the junction between the two fittings.
2018 T@B 320S. Tow vehicle: 2020 Toyota Hylander Hybrid
Somebody else had a similar issue recently. The connection is not pushed together correctly, the gray ring should not stick out that far.
Now that I look at that, it also looks like the gray ring is not quite straight and maybe that is part of the problem?2018 T@B 320S. Tow vehicle: 2020 Toyota Hylander Hybrid
- 920 Introductions
- 74 Teardrop Groups & Links
