The 2023 tab 400 comes standard with the Victron SmartShunt and Multiplus both of which are “Bluetooth enabled and can be configured or controlled with the VictronConnect app”. (All of this information is according to the manual.) However, while the app found the SmartSolar component without any issues, it cannot find the other two components. Thoughts? Suggestions?
On another related note (sort of), we’re out on our first extended boondocking adventure and the stock solar/battery system seems to be handling our modest power needs quite admirably, despite all the dings in the solar panel from a recent hail storm: fridge, minimal lights, minimal water pump, fans, phone/tablet charging, NBA playoffs (go nuggets!)…
— Richard R.
Front Range of Colorado
2023 TAB 400 Boondock
2022 GMC Canyon2023 F150 Hybrid (PowerBoost drivetrain)
0 ·
Jericho, VT
Sold 2023 Tab 400
Sold 2018 T@B 320S
The fridge will take you down within two or three days without sunshine (that does not describe Utah however). It is really hard to tell the charge remaining without the shunt, but if the controller is in "float" mode, then it has sensed the current dropped nearly to zero and passed through "absorption" phase (not truly needed for LiFe4Po batteries, but part of the charge cycle nonetheless).
The solar controller is always connected to the battery even with the battery switch off, so that is an option to help get you back to charge without a load. Of course you would probably want to move your fridge stuff to a cooler
Jericho, VT
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
Jericho, VT
Jericho, VT
First, thanks for all the helpful comments. It was never really a disaster situation. Worst case scenario is we'd have to pick up a cooler and some ice and then revert back to our tent-camping routines, which we've been doing for decades. As it turns out, the battery drain was likely due to the inverter which we were using to charge a wifi hotspot back in the cubby by the bed. (Rant: why didn't they put a standalone 12V usb port back there? Next to the bed is where most people charge their phones/tablets. Rant over.) Also, I tended to keep the fridge cranked all the way up which may have contributed. I kept the inverter off, turned the fridge down a bit at night, and the battery maintained a good charge throughout the night.
The VictronConnect app is another story. I've tried several things including pulling the fuse, but no luck. I've come across a few blogs/internet stuff (including a thread on this forum https://tab-rv.vanillacommunity.com/discussion/comment/196663#Comment_196663) in which it was necessary to pull the fuse AND put a blanket over the solar panel to eliminate any residual power coming in. I'll give that a try although it seems you should only need to temporarily disconnect a solar input wire on the SmartSolar unit to achieve the same thing.
Oh, and BTW, we had an absolutely fantastic trip despite these little bumps! The BIG bumps on I-70 all the way through Colorado were a different story...
