Has anyone tried to find a way to drain Alde without tearing your bed apart after every trip?  This seems like design flaw, given that all other drains/plumbing valves are very easy to access.  Don't have the answer, but have considered the following:
1. Move or add flapper valves under trailer on the YFV drains.
2. Cut an access hole from the Nautilus panel.
3. Add a push/pull rod to the yellow handle with small access holes under trailer.
4. Some electrically controlled valve (seems like overkill).
5. Just drain the fresh, cold and hot water drains and leave the small amount of water in the Alde tanks.
Looking forward to hearing more ideas/comments from the TAB brain trust.
                2017 T@B 320 Outback 2023 400 BD (IdahoTabato) pushing a 2023 Volvo XC90
0 ·
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
Some day I’m going to install hinges on the outboard edge of the platform so I can open it with one hand and flip the valves with the other hand. That should speed up the process.
I don’t drain the alde after every trip…maybe every other and I also don’t screw that panel down. In the event of an emergency I didn’t want to worry about unscrewing that panel.
2020 Tacoma TRD Off-Road
Sold 2023 Tab 400
Sold 2018 T@B 320S
