Tip: Outdoor command strips
Chopin
Member Posts: 47
I think a lot of us use command strips to attach extra hooks and storage devices inside our campers. I’ve found however that with the extremes of temperature these can come unstuck. Solution: the outdoor command strips seem to hold up much better inside the camper as they are designed to work between freezing temps and up to 120 degrees.
Command 17615CLRAW-ES-E, 4-Medium and 2-Large Strips (17615CLRAW-ES), Clear-Outdoor Refill
https://www.amazon.com/dp/B00SH2CG2S/ref=cm_sw_r_awdo_navT_a_2BY0TYMBNTGMDZ537W5P
9
I too, use the strips everywhere in the TAB. I even use them to hold shelf paper in place so I can remove it if I don't want it. Thanks so much for the tip.
