TAB leveling blocks
TabithasOwnersTabithasOwners Member Posts: 1
edited June 2023 in Tips & Tricks
I was trying to decide how to strap on these leveling blocks from Walmart with a bungee cord, or a ratchet strap, or zip ties. Then I realized if you put the bottom block under the rack and the other blocks on top of the rack, you can just screw the big plastic bolt all the way through and they are VERY secure. Thought some of you might appreciate it.
  • Richard_RRichard_R Member Posts: 41
    I just bought those exact blocks and I was a little dismayed because I’m starting to run out of real estate in the box. But now… Thank you!
    — Richard R.
    Front Range of Colorado
    2023 TAB 400 Boondock
    2022 GMC Canyon
    2023 F150 Hybrid (PowerBoost drivetrain)
