The 3 way in our 2021 Tab 400 has been acting funny. It has slowly gone from not cooling well (in fridge section) to not cooling at all. Same on AC or propane. Freezer however is perfectly fine. I checked the thermistor in the fridge and it's reading fine - around 9kohms in 75 degree ambient, and drops when I hold it between my fingers. I tried moving it to another fin in the fridge and there was no effect. What DID seem to help was removing the thermistor from the fins entirely and laying it while connected on the shelf in the fridge (if I disconnect entirely I get an error 13). With that approach, it cooled the fridge overnight. I then went back and tried another position on the fins and it went back to misbehaving. Anyone had a similar issue? We are on a weekend trip tomorrow and if I can cool the fridge with the thermistor lying on the shelf in the next few hours I'll go with that, otherwise I have an ice block in the freezer to use the fridge as a rudimentary cooler though that might backfire if the fridge thinks it's already cold and doesn't even cool the freezer at that point. Help!
If needed I'll call norcold next week but hoping someone's had a similar issue and has a proposed resolution..
1 ·
Hopefully this helps anyone else with an underperforming 3-way Norcold!
Tom
