First time set up of PaHaQue tent
2011 Subaru Outback
Rockford, Illinois
Vito, I have abandoned tent stakes. I use fender washers and Timber lock screws 10' in length. I screw them in with the cordless drill. Most importantly they come out without throwing out your back! You can get them at Nicholson Hardware in Rockford.
John
2007 T@B
Rockford, IL
Timber lock screws are great.
We set ours up for the first time yesterday. In the back left corner, there is a 12 inch gap between where the tent stake goes and the ground. I notified Dylan, he will notify Paha Que. Very disappointed.2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
Here's the picture.2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
I just wish our back corners would seal. There is no way anyone could safely camp in our tent because many of our campgrounds are in poisonous snake territory. Wish I could get them sealed.Judy and Mike - Central KY 2014 T@B S M@X towed with Chevy Trailblazer Nights in the T@B: 32
Can you post pic of how you are using timber lock screws? ThanksJudy and Mike - Central KY 2014 T@B S M@X towed with Chevy Trailblazer Nights in the T@B: 32
judymac, I would take photos but the screws are in the t@b out at the hangar and I will not get out there until next week. So for now, I will try to describe. I put a large fender washer on to the screw. The washer creates a circular flange on the screw. The flange prevents the nylon loop from popping off of the top of the screw while it is screwed in the ground. I purchased a bit that is appropriately sized for the screw (it is also in the t@b) and put it in the chuck of the cordless drill. I can give you the visual next week. The Timber Lock screws are hardened and really strong so I have found them to work quite well. There are other brands as well. Someone on the Yahoo forum had the idea(maybe the famous Richard Lewis), not my original thought.
John
2007 T@B
Rockford, IL
I set up our tent for the first time this week. Overall, I really like it. We had enough room for a cot, small table, and two chairs. On the negative side, I was disappointed with all the velcro. Especially where it attaches over the wheel. For those that travel and set up frequently, I would think one would be replacing it often. Once it's dirty, etc it doesn't work all that well. I was wondering how zippers might be used in place of velcro, like in the back corners? Some things seemed like afterthoughts, like the little flaps at the handle. But in the plus column, takedown is a breeze. Ours was damp, so when I got home, I set it up again. This time by myself and it went up quickly. As I said, I like it very much.
Martha in VT w/Mahit@bel, '15 T@B CSS-Max & '15 Subaru Forester -
Am I missing something with this tent or is there a way to use it with the T@b step in use? It seems that the skirt requires the step to be folded in, making it a big step to get into the camper. Plus, I learned that when setting it up its important to make sure the floor of the tent that is along the edge of the T@b be laid right up to the edge of the T@b before staking the tent corners down. Otherwise when stepping on that part of the floor you keep "ripping" the velcro holders loose. Not sure if I explained this clearly enough to make sense, but I think future uses for me will be easier now that I figured this out. And I wish Little Guys would have made built in little external hooks over the wheels that the skirt would attach to, rather than having to stick velcro taps onto the wheel fender. But overall it made quite a difference in enjoying our camping experience by more than doubling the usable "interior" space for us.2016 T@b S Maxx
2011 Subaru Outback
Rockford, Illinois -
Vito, I watched the You Tube video on setting up the tent as I set it up. And sadly the steps can't be used. I bought a folding stepstool to use. You would think that for the money they could figure some of these things out.
I agree with you. I guess I will buy a small stepstool as well. I'm getting too old to be stepping up directly in and out of the T@b all the time (fortunately there is the outside grab handle which does help).2016 T@b S Maxx
2011 Subaru Outback
Isn't the reason the steps aren't available is to keep it sealed so bugs won't get in?
That would be my reasoning, but I haven't asked Paha Que. Also to keep other animals out other than your own. If you think sbout it, with the different elevations the step could be at any number of campsites, it's actually good forethought to not have a slit for the step because it would be totally open if they allowed for all elevations, and then here comes the raccoons for dinner!PXLated said:Isn't the reason the steps aren't available is to keep it sealed so bugs won't get in?Verna, Columbus, IN
- 917 Introductions
- 73 Teardrop Groups & Links
