Hello Tabbers;
The discovery of gushing water out the drain underneath the tab happened when I turned on the Alde for some hot water.  Then I opened the door just in time to see a huge puddle on the ground from the Alde tank.  After changing out the regulator, checking for internal flooding, and testing the outside spigot, apparently water flowing directly from the spigot runs directly through the Alde and out the drain under the tab.  Presently there doesn’t appear to have any water in the tank.  What could have happened?  Plus what steps are next please?  Any help is greatly appreciated!
                0 ·
"In a calm panic, I was wondering the replacement cost for a 3020 unit" -- as we are in the middle of this now it runs about $3k installed just for the boiler unit.
I am sorry for the delay in responding—thank you for your comments! Replacing the boiler unit is a challenge; did you opt for an Alde or something else? How’s it working now? Lastly, do you mind describing what caused the boiler to break?
