How to replace outside 1/2” screw cover (molding) between 320 tail lights?
MadCityJack
Member Posts: 110
After returning from a NuCamp dealership (160 miles one way from home) I discovered worse cracking on the 1/2” trim piece that goes between the left and right tail lights of our 2017, 320 TAB Q. The dealership inspected potential sources of a slow leak into the rear compartment of our TAB and concluded it was not the tail lights. They attributed the leak to a cracked glycol reservoir. They replaced the reservoir and their assessment of the tail lights is they were not the source of the leak. Time will tell.
I wonder if this is a generic RV molding that I might purchase and possible instructions on how to remove the old one and attach a new one? Thank you in advance for any suggestions!
Edit: I searched “cracked trim” and that turned up a bunch of posts, but mostly for the larger external molding that goes over the roof and side walls. I will contact NuCamp.
2017 T@B 320 Q Max
2018 Toyota Highlander, XLE
Wisconsin
Wisconsin
I am surprised I had no comments…2017 T@B 320 Q Max
Wisconsin0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
