Electronic Jack install problem
2018 T@B 320S
Just installed Lippert e-tongue jack.
Previously I tried to install a look-alike model, cheaper, it did not work, it was supposed to be self grounding, even after I grounded it as per instructions by grinding off the paint under the nut.) So I bought the Lippert.
The Lippert says to install by putting the lead from the jack onto the grounded battery.
Below: The Large red wire from the jack attached to the
battery on top of the lead for the camper
We switch the Jack on and nothing happens.
1)
The battery is new and fully charged, the T@B is home on 30Amp shore power
2) If I pull the plug on the shore power the DC components (and the ceiling fan continues to work)
3) The Positive post has the Green wire from the junction box which I added at the terminus some red tape for clarity.
Below is the box where the battery leads go
Here is the junction box w/ the wiring for the battery to the camper
How to make the jack think it is grounded?
The trailer frame may not have connection to 12V ground. If you have jumper cables connect the battery negative to a shiny bolt on the frame and see if it works then.
Yes, I am moving toward making a separate ground. thanks
Tom
2024 Hyundai Santa Cruz and 2018 T@B 320S -
Well, I added a separate ground, from the battery to the frame (steel, not aluminum, i checked) still no up and down for the jack, i deburred the seat under and on top of the frame where the jack meets the A-Frame, no luck from the e-jack. Checked all 12 volt fuses, all good to go.2024 Hyundai Santa Cruz and 2018 T@B 320S
Hmm that certainly becomes interesting... I think the likelihood that you got two defective jacks is very small. Can you bench test the jack with a jumper pack or similar power source ? These things are dead simple, an electric motor and a power reversing switch.
I am going to swap out the battery…the grounds are solid…i have a new spare battery…very strange2024 Hyundai Santa Cruz and 2018 T@B 320S
In the world of automotive repair this is called the "parts cannon". With the trailer hooked up to shore power the condition of the battery is irrelevant, if you haven't done so yet connect the trailer to 120V and see if it makes a difference. Or, put a voltmeter on the battery and check the voltage drop when trying to move the jack.
Too soon?
I am in expert mode2024 Hyundai Santa Cruz and 2018 T@B 320S
The ceiling fan has more rpms when i plug shore power back in, so then my multimeter died…trying your other suggestions…thanks2024 Hyundai Santa Cruz and 2018 T@B 320S
If you have a spare charged 12 volt battery available, try running the jack directly from it. If that works, then you can engage in installation trouble shooting.
Troubleshooting is a step by step process. Always start at the beginning. Rule out everything step by step. Never assume anything is "OK" unless you verify it. Do not skip any steps. There is a reason why phone support staff are trained to ask you, is it plugged in?
You will figure it out. -
Well, it works if i use the portable jumpstart battery thing…good enough for now!2024 Hyundai Santa Cruz and 2018 T@B 320S
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
