Tross2023
                    Member Posts: 77
            2018 T@B 320S
Just installed Lippert e-tongue jack.
Previously I tried to install a look-alike model, cheaper, it did not work, it was supposed to be self grounding, even after I grounded it as per instructions by grinding off the paint under the nut.) So I bought the Lippert.
The Lippert says to install by putting the lead from the jack onto the grounded battery.
Below: The Large red wire from the jack attached to the
battery on top of the lead for the camper
We switch the Jack on and nothing happens.
1)
The battery is new and fully charged, the T@B is home on 30Amp shore power
2) If I pull the plug on the shore power the DC components (and the ceiling fan continues to work)
3) The Positive post has the Green wire from the junction box which I added at the terminus some red tape for clarity.
Below is the box where the battery leads go
Here is the junction box w/ the wiring for the battery to the camper
How to make the jack think it is grounded?
Tom
Troubleshooting is a step by step process. Always start at the beginning. Rule out everything step by step. Never assume anything is "OK" unless you verify it. Do not skip any steps. There is a reason why phone support staff are trained to ask you, is it plugged in?
You will figure it out.
