Hi - I switched out my dealer supplied Lead Acid Deep Cycle marine battery - believe it is a 75aH - for a Weize 100 aH self heating lithium. I have a 22 Tab 320 Boondock equipped with the factory solar panel. I went into the settings menu of the Victron controller and selected the smart lithium LiFePo4 option. This setting provides absorption voltage at 14.2 V. and Float at 13.5. Temp comp is disabled. My issue is that I frequently Boondock and was hoping that the Lithium battery might provide more than one day of usage - I do run the Isotherm fridge on a low setting, and try to use other power conservatively. I feel as though I was able to get a full two days out of the original battery. Am I being unrealistic in hoping for better performance from this battery? Unlike the lead acid battery, this one shows either full or almost full on the Tab's control panel - then suddenly when its done everything just shuts down - no warning. Should I have spent the $$ and gone with BattleBorn - or do I need two? Would appreciate comments from those who know more about this than I do!
Thanks!
TV '21 Highlander Hybrid
Your settings are only slightly off of their recommendations.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
