Victron smart charger
stp2136
Member Posts: 16
Anybody know any technical reason why one shouldn’t connect a Victron smart charger to a lithium battery simultaneously with the WFCO and the Victron solar charger? Trying to get around the WFCO non recognition of lithium batteries.
This thread has a couple of comments about it. You could probably wire any of the lithium compatible smart chargers this way. See AldebaranJill's comment in this thread. https://tab-rv.vanillacommunity.com/discussion/16168/external-smart-charger/p1
Towed by 2014 Touareg TDi1 -
I have a Victron smart charger and put a switch at my lithium batteries to turn them off when on shore power. I let the WFCO supply 12 volts to the T@B and I can switch the Victron charger on if the lithiums need charging and switch back to batteries when I disconnect from shore power. Works just fine.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York2 -
I have this nearly exact setup and it works fine. My WFCO older and does not have an Li option.stp2136 said:Anybody know any technical reason why one shouldn’t connect a Victron smart charger to a lithium battery simultaneously with the WFCO and the Victron solar charger? Trying to get around the WFCO non recognition of lithium batteries.Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA1
