I have. The black rubber seal on ours wasn’t fully seated and created a valley for the water to collect in. I opened the screens and used a rubber mallet to get it fully seated along the top. Could be your issue.
Same issue here. Ours was due to the butyl tape pulling away from the aluminum body. Water was running off the top of the window and down the rubber seal but because the butyl tape had failed it ran straight down the inside of the window frame and out the bottom to the inside of the camper. I had to pull the rubber seal back and reapply some butyl tape but all seems well for now. To be proactive I redid the stargazer window’s butyl tape at the top corners as well.
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
2020 Tacoma TRD Off-Road
