What are the proper methods to protect tires when TAB not used for weeks?
Playc
Member Posts: 234
In addition to lowering the stabalizers, leveling, ...
Is it possible that the weight of the TAB (while in garage storage) can cause a flat tire in weeks?
2015 S Sofitel, Austin/Houston
No more so than your tow vehicle would have a flat tire after staying in your garage or a storage gargle for a few weeks. The T@B weighs approximately 1,680 lbs, dry weight, which is less than most 6 cal tow vehicles.Playc said:In addition to lowering the stabalizers, leveling, ...
Is it possible that the weight of the TAB (while in garage storage) can cause a flat tire in weeks?Verna, Columbus, IN
I recommend "rotating" the tires. That's why I take my Tab camping every weekend. Other than that keep them out of the sun while in storage and dry if possible.Norm & Pat. 320 S Outback Utah or somewhere else.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
